Closing Windows Externally...
Do you use your key/remote to close your windows?
If so, how often do you use that feature?
Re: Closing Windows Externally...
nope use the key fob to do that and also close the windows
Only use the remote window closure if I've forgot to put the windows up. Which is not very often. Or every once in a while to check all is ok.
I usually bring the windows 95% up, using the window switches near the handbrake...
I then use the key, to close the remaining gap...
I find that it's easier to close the doors that way, as the gap allows the air to escape...
I'm surprised at how many people, didn't even know that they had this feature...
I just press the button on the alarm remote
Mark1 wrote:I just press the button on the alarm remote
^^ This
I should have added "as I don't have any locks in the handles".
Same as Mark, i am delocked and windows go up with a press of my alarm button
i dont open my windows as i stay on Scotland and dont like getting wet
Robs-se wrote: Same as Mark... I am delocked and windows go up with a press of my alarm button
What Alarm???
Clifford of in mine.
Mark1 wrote:Clifford of in mine.
So you replaced the Standard Alarm/Immobiliser?
That's still on the car and working. www.clifford.com.
EddeyDancer wrote:Robs-se wrote: Same as Mark... I am delocked and windows go up with a press of my alarm button
What Alarm???
Mines an old Cobra alarm, bypasses the standard and seems to drain the battery. Not got round to changing it yet
