G cam oil seal
G cam oil seal
Hi iv just got a set of g cams for the Calibra which camshaft oil seals do I get or are they the same any way the engine is a c25xe also is there anything I should be aware of fitting them any info appreciated thanks Daz
Re: G cam oil seal
I've just fitted a set to mine, there's no difference in size for the oil seal and no difference in fitment. It's the same procedure as if you was re fitting the 'A' cams. Well that's what I did lol.
Re: G cam oil seal
Thanks everyone
