side wing repeater lamps
just got these today ..better than those dome nipple ones and these are led
Mse495.
Mse495.
markse495
Re: side wing repeater lamps
They will look much better.
Cheers mark , ive got a fair few bits to have done to her now, also ordering my black angels on tuesday
Mse495.
Mse495.
markse495
I'm on my 4th set of those, admittedly not from that company, but i understand there is only one manufacturer...and they fall apart and let water in!
MadOnVaux! wrote:I'm on my 4th set of those, admittedly not from that company, but i understand there is only one manufacturer...and they fall apart and let water in!
WOW...
4th Set
I think the 'Self Adhesive' system will always be a flunk...
I had to do some basic wiring and modify the holes in the side guards (wings) to fit the Monaro Style lights, but it wasn't that hard to do, for a quality long-term result...
EddeyDancer wrote:
WOW...
4th Set![]()
I think the 'Self Adhesive' system will always be a flunk...![]()
It wasnt the adhesive that was the problem though!
MadOnVaux! wrote:EddeyDancer wrote:
WOW...
4th Set![]()
So what is the problem?
EddeyDancer wrote:So what is the problem?
The front lense seperates from the plastic base where the LED's are and lets water in...or if it doesnt seperate, the seal between the lense and base is that bad that water gets in anyway.
Ive also had a pair were only half the LED's worked!
MadOnVaux! wrote:EddeyDancer wrote:So what is the problem?
Well... lets hope it dont happen to me my callys garaged most of the time anyway.
markse495
