4x4 again
4x4 again
Put the new sports transfer box in today so all running 4x4 again as it should be.
Getting the old one out was a pig as every bolt that was a tricky to get to had grotty threads and where tight all the way out.
Here's a tip if you ever need to fill a TX box with new oil.
Remove this bolt (seen missing) as this one and the lower one actually go into the inside of the casing and leaving it out will allow the new fluid to fill the box in less than 1 minute, as it allows the air to come out.
Also, if anyone has a gearbox and feels the gear change is a bit clunky, drop the oil and refill with EP75-80 oil.
My box only had about 1 litre in it, and was noisey and clunky, it's now smooth even when cold and very quiet.
Re: 4x4 again
good to see your back with your 4x4 dude. also on filling a txb box. i found the best thing was a fairy whashing up bottle. you can get a bit of pressure to push the fluid into the box also
- Club Member
Re: 4x4 again
Nice one Andy glad you got it all sorted
Re: 4x4 again
Yes, the casing is from '92 and was actually built in may '08 according to the test data and warranty.
Again, with the gearbox now smooth it makes the car so enjoyable to drive, its even bettter than when I first bought it, so must always of been low.
Re: 4x4 again
good to see it all back together Andy now all ou need to do is give it a good run to run it in ill put the kettel on if you want see you in 6 hours
Re: 4x4 again
Thanks steve. I'll get some cream yum yums on the way. LOL
Re: 4x4 again
Good job Andy, those bolts can be a bit of a pain, ive been tempted to loose the tricky one a few times when putting it back together
I remove the bolt to the left of the temp sensor when filling, also acts as a level gauge when filling not that you can go too far wrong if using the vauxhall fluid
Re: 4x4 again
glad you got it sorted, you now know what a pain they are to do
on the plus side I managed to lift the gearbox and transfer box in one back onto the engine this time, just got to fill both nowwith oil then subframe back on then she's on the road again
Phantom
Re: 4x4 again
Great news Andy, as you say I now know what's involved in changing one, and mine was 6' in the air.....Cant imagine how you do it at home.
Users browsing this forum: No registered users and 63 guests
