cal16v's WIP
cal16v's WIP
Looks good - Have been thinking of something similar myself, dark in the garage etc but then I thought it will just have me vacuuming the mats more!!
Re: cal16v's WIP
Thank you.
I'm having a few difficulties with the painter ATM TBH.
But after explaining to him that they're can only be 1 winner in these types of situations I'm pleased to say he has now come around
Re: cal16v's WIP
Photo time...
More to come...
More to come...
Re: cal16v's WIP
looking good mate keep the updates coming
'Once Driven Forever Smitten'
Re: cal16v's WIP
A belated thank you for the replies. Not much going on of late but now ready to start on the front end. Plan to order new control arms ,air-con compressor, cv boots, a few suspension bits n pieces, sump gasket and front pads. I already have springs and shocks to go in so the plan is to do this all at once.
Re: cal16v's WIP
Nice wad of cash spent with Kieron @ Autovaux overnight. Looking forward now to delivery.
Re: cal16v's WIP
More pics...
Re: cal16v's WIP
Searching for a new sunroof seal. Anyone found a replacement from another model/vehicle?
Re: cal16v's WIP
cal16v wrote:Searching for a new sunroof seal. Anyone found a replacement from another model/vehicle?
Ok found a replacement seal locally so going to try it out a bit before putting up any pics and details. If it turns out well I'll post up contact details etc.
Some pics of the profile;
Re: cal16v's WIP
Found another set of Cali tail lights to replace mine. My nearside unit has started to crack and is dull. Thinking about having them fine sanded and clear UV coated. Anyone any opinions?
Re: cal16v's WIP
Also found the roof headlining starting to come lose in the rear. Not happy at all because this was professionally recovered not more than 2 years ago.
It's a bugger of a job taking the roof card out and not one you want to do too often for the sake of the card so I will recover in leather and will never need re-doing again.
Edit
Not wasting any time on this;
Edit
Re: cal16v's WIP
Not much can be done as I'm still waiting on parts delivery. Finished recovering the roof late last week so that's now ticked off the list. Bonnet stalk and a few other pieces sent for nickel plating (mostly pieces that needed re-doing tbh). Sunroof surround rubber has arrived so to see how that fits and holds up with some use. Mesh on the the rear bumper leaving the front to be done probably next week at this rate.
Re: cal16v's WIP
Meshed the front bar and it's ready to go back on. Just need to finish fitting the new sump and gasket. A freshen up for the exhaust with a coat of high heat and it can all go back together again.
