Engine knock is the
characteristic vibration caused by uncontrolled combustion. This happens when
the ignition spark is too far in advance of the maximum position of piston
travel. This is bad as it's inefficient, causes worse emissions and can
result in cylinder temperatures high enough to damage pistons. An ignition
spark advanced close to the point of 'knock' is the most desirable - it is
more efficient and provides the most power from combustion.
Knock sensors are basically small flat microphones which are bolted onto the
engine block to a specific torque (20nm). The ECU uses the knock sensor to
listen for engine block vibrations of a certain frequency which mark the onset
of knock. Using the sensor feedback it advances the ignition spark to optimum
(auto tuning). If either knock sensor detects knock then the ECU knows it's
advanced timing to far for the current engine running conditions and backs off
(retards ignition timing). This all happens very fast; sensors are scanned
every 100 milliseconds.
There is a known issue with knock
sensor faults on the V6. The fault comes and goes by itself, sometimes
associated with a slight drop in engine performance, sometimes not.
Occasionally you may get a
16
or 17 fault code registered.
The V6 has two knock sensors; one for each bank of three cylinders. Number 1
knock sensor is at the front of the engine, number 2 at the back.
Code 16
(front knock sensor / number 1) appears to be the most common; maybe this is linked to the fact that
the wire for knock sensor 1 is longer and runs over the top of the engine -
and V6 engines run hot.
The Motronic 2.8 ECU scans the knock signals every 100 ms and detects a fault with one of the knock sensor signals if:
engine rpm > 1400
and
actual knock sensor value in mV < reference look up table value in mV (depends on actual rpm) for 20 consecutive scans
The fault code is stored in ECU memory if this condition persists for > 10 seconds
The ECU defaults to a safe mode if the above fault condition is true AND:
engine load > 2 ms
and
coolant temperature sensor > 45 deg C (113 F)
During safe mode the ECU retards the ignition by up to 13.5 degrees crank angle (amount of retard depends on actual rpm) - hence drop in performance sometimes perceivable; the higher the rpm, the greater the retard angle.
Code16 front knock sensor faults are most commonly caused by a poor quality wiring loom
section between the ECU and sensor connector. It is rare for the sensor itself
to fail, but not impossible. You can help the situation by ensuring that the sensor
connectors are clean and secure and the sensor is tightened to the correct
torque setting (20nm). It is also worth checking the twin core wire attached
to the sensor. There is one particular area where the integral sensor wire
enters underneath the plastic engine cover (to the connector). Check for
breaks in the wiring here; this can be caused by the engine cover rubbing
against the wire. If you really suspect that it is a faulty sensor and not
wiring then
try swapping with the other good sensor (on the opposite cylinder bank) to
confirm. It was rumoured that the knock sensor wiring loom was improved on
later ('96 >) V6's. This does not appear to be the case as late V6's are known
to suffer from bad KS wiring loom problems too.
If you've checked for wiring chafes/breaks, cleaned the connectors, swapped
sensors over and you still experience an intermittent knock sensor fault, the only
answer is to replace the wring between the knock sensor wiring connector and
the ECU. Unfortunately (unlike the 16v) it's a single cable from sensor plug
to the ECU and runs through the engine bay bulkhead to ECU. Replacement of the
poor quality degraded wiring is the only way to fix this problem.
Use of good quality, high temperature, shielded wire is highly recommended
(avionic grade wiring).
You may get away with just replacing the
loom section (two wires for knock sensor) between the knock sensor connector
and the engine bay bulkhead. Where you need to splice back in to the original
wires make sure you use good quality connectors or soldered joints. If you
think about it the front knock sensor loom is probably the longest section and
it runs over the top of the hot running V6 engine. Close proximity to a very
hot engine, long length of loom and substandard original loom quality all
contribute to making this a common fail point.
In addition to replacing as much of the loom as you can, you may
also see some benefit from fitting 'ferrite rings'; just like the ones you see
on computer monitor cables.
